Radiator upgrade? Tow help
Andy Rubalcaba
Riverside, CA
Hey y'all, I'm in need of the radiator upgrade that comes with the HD tow package on these EL Expy's, mine did not come with the HD tow package but I will be towing a bigger travel trailer eventually ( currently only tow a popup trailer which is very light ). I'll be around 5,000lbs to 6,000lbs on trailer weight, so I want to get the beefier radiator if anyone has a link to it? any tips on the differences so I know that i'm not getting ripped off? I assume it shouldn't be too bad to swap out.
I also need to do the trans cooler, not sure if that is more complicated and may need to pay a dealer to install? still need to look into that one. Any other upgrades that I should be doing? I already have new powerstop brake pads front and back ( red EVO or w/e they are called, like a step up or two from the basic ones i've seen ), not sure if these fords have bigger rotors that I can buy and install?
lastly there's the issue with the trailer pigtail, but I had seen someone did a wiring job on theirs and converted it into a 7pin connector, so i'll be exploring that as well ( gotta have those trailer brakes of course ). I appreciate any help, thanks!
My expy has 166k miles on it, new air ride suspension ( strut and bags are new assemblies ), so I feel i'm in a solid platform to haul a mid sized travel trailer ( probably keep it about 27 ft or less, and under 6k lbs tow weight ).
