johnnynewtown
2018 Limited. After turning off vehicle and just sitting listening to music, the radio would stay powered up for the usual Ford 10 minute time frame. Now it shuts off after about a minute. Any thoughts?
I just looking to get it back to the 10 minute delay. Not sure it I changed something in the menu without knowing but now it just shuts off after a minute or two.
Yup, had the same issue. Posted here with my issues and sure enough - battery needed a full charge. Good chance I need i'll need a new battery soon as well.I don’t remember anything in the menu. I would first suspect a battery issue.
I think I am in for a new battery as well. Auto-start stop hasn’t worked for a few weeks despite being driven daily for at least 45 minutes. Radio has shut off immediately after shutting off the engine. Intelligent access door handles and tailgate are intermittent on if they work or not. I tried charging the battery, but I received an error on the slow charge setting.
Do you have a high quality AGM charger? If not one can probably save it. If you do then it’s probably toast. People need to remember that an AGM at 12 volts is around 50% state of charge. But you can only use up to 50% so it basically 0%. Usually anything below 11 volts causes damage. My Expy and battery seem very consultant with the auto start and door handles not working around 12.3 to 12.4 volts. And it takes about 6 hours to top it back off with solar or a charger. Much longer than a drive somewhere.
