Random Check Advance Trak with ABS LIGHT on
Eightiesrock80
Frankfort, IL
Code shows left front speed sensor not connected but it’s brand new I just installed it. Has anyone ever had a problem with the left front wire harness that comes from under the coolant reservoir? I removed the reservoir and noticed that the wires are crushed by the reservoir I’m wondering if the one of the wires is pinched causing it to intermittently work and not work correctly because eventually the lights go off and there’s no problem at all and everything works normal
