Rear A/C not working
hokiepoke
I have a 2008 exy that had the rear AC go out all of a sudden. The front works fine. I have changed the blend doors, checked the power distribution box fuses and relays, the compartment fuses, and the relays in the very back by the hvac unit. As best I can tell with my cheap voltage meter I'm not getting power to the wires running to the blower motor. I'm going to exchange the blower motor but I'm at a loss and any help would be appreciated
stamp11127
Temple, Georgia
What good is changing the blower motor if there isn't power going to it?
Check fuses first then hit the wiring diagrams to trace the circuit.
Yes if you are not getting power before it.... never change it... you have somewhere BEFORE the motor where the path of your electricity is broken... replacing an item after that point does absolutely nothing... how did you check fuses? You can't just look at them. Every time I think a fuse looks good it's still bad when it's suspect. On mine the aux blower one is #11 in the power distribution box (2007).
