Rear Air Suspension Trouble
Peter Mensonides
Turlock, CA
I'm having an issue on my 2007 Expedition EL, with the rear air suspension not working. The rear end is completely lowered and will not come back up. I've verified that the air suspension compressor does turn on, but the suspension bags are not inflating (I assume so, because the rear remains completely lowered). I disconnected the airline/port directly at the compressor/dryer to try and determine if air is indeed coming out of the compressor. With that line removed from the port, should I expect to feel a strong air push out of the compressor, like what you get from a portable air compressor hose? Because it's more like a "trickle" of air.
The air pressure is small due to the line size and the small compressor size. Nine times out of ten it's the air bags or airsprings the proper name that rot out and leak. They last about 8-11 years depending on usage and if they dry out. Most customer's don't know that spraying down the bags with silicone or rubber spray lengthens their life. You can replace the bags or swap in coil springs all 4 corners.
P
Peter Mensonides
Turlock, CA
Thanks for the reply, 1955moose. Neither rear airpsring is filling; isn't it unlikely that both airsprings would suddenly stop filling at the same exact time?
Very common. If in doubt have someone check it out for you. Suspension inspections are usually free or low cost. When my 84 Lincoln front bags went out, both sides dropped. At first it would pump up by flipping off switch in trunk, then flipping it back on. You might try that with yours. Switch should be in hatch area, check owners book for location.
1997SCEBFEX
Northwest Panhandle
different model year, but my rear bags dropped due to the air union coupler failing which is under the master cylinder as I have four-corner load leveling suspension. part number here if it helps: Ford # 2L1Z-5B322-AA
I also replaced compressor due to catastrophic failure, and rear bags; ordered as a kit from Arnott. my fronts are an air shock/strut combination.
Arnott G97NEPD & Arnott A-2153
++ on spraying down with protectant, as well as soapy water on connections to reveal a leak.
report back.
The earlier ones like 1 St and some 2nd edition had the switch in passenger side foot well. Gixer do you know what year they went with the steering wheel method?
gixer2000
Retrofit or Bust
Massachusetts
Unfortunately I don't. Mine is an 07 so it 1st year 3rd gen and its in the cluster.
Maha2965
West Virginia
I have a 3rd gen the compressor quit few days ago. Was told to replace the air suspension relay that looks like a heat sink module. Cant find the location of this part? I have check all fuses and relays all good and replaced to just confirm. Anyone know where this relay/module is located with the heat sink of it?
I don't know 100% if this is your relay, but from what I came up with it's relay #108. 2 ND row from bottom, 3rd one from right. You might try a relay next to it, or stop by Ford or wherever and just buy one. I couldn't tell if it was 40 or 50 amp, but when you pull it you'll know. You can also jump the terminals where relay plugs in. Compressor should run when you do. I think it's terminal #30 12 volt to #87. Is that correct guys? Been awhile since I did that.
gixer2000
Retrofit or Bust
Massachusetts
In the 1st gen models it looked like a heat sink and was located in the passanger wheel well. 3rd gen models its in the main fuse box under the hood. This picture from alldata is hard to read but it's top left corner closest to the connection from the battery
Maha2965
West Virginia
Mine is 3rd gen I did purchase a new relay for the one in the battery fuse box (main fuse relay) area. Parts store said I needed the heat sink module however nowhere shows it but will sell you a part for it. Still nothing I'm tempted to now buy a new compressor to install? What would you suggest?
Easiest bet is pull the plug at the compressor, if your getting power to it your test light or volt meter should show 12volts. Maybe one here can tell you which wire is 12 volts.
gixer2000
Retrofit or Bust
Massachusetts
Unfortunately alldata doesn't provide much info on troubleshooting or schematics so I can be much help but I would start with a scanner that will read air suspension codes.
I use the bluedriver and if the system is showing a fault it won't engage the compressor unless the fault has been cleared. Also the compressor will not run if any doors are open. Its possible the relay fixed your issue but if you don't clear the fault the compressor won't start.
You could try disconnecting the battery for 30min and see if the compressor starts after.
Maha2965
West Virginia
I just replaced my air compressor, relay, all fuses associated with the suspension and I still cant seem to get the compressor to kick on. Any clue what I need to check replace? Any quidence much appreciated because drawing to my wits end
You did exactly the opposite of what I and others said. You shotgunned parts at a problem, rather than do the diagnosis. See if you checked for power to compressor, my bet it's 0 volts at hot lead. Like Gixer said, it could be something within the computer. Try the battery reset as he said. If that doesn't do it, you might have to have a specialist finish the job. Sometimes your sanity is worth more than a few bucks. Electrical issues are tough. I've more than once conferred with others to fix a problem that was above my knowledge. Happens to all of us.
