Rear camber problem
SC19
North Carolina
Hi everyone, just put new rear struts ,sway bar links, and rear upper control arm on both sides on my 07 expedition EL...after I put wheels back on and lowered it down, I noticed camber was definitely negative a good bit..I even measured old and new control arm which are not adjustable but were same length. Alignment shop couldn't do anything because of nowhere to adjust the camber..recommended i get a camber bolt and install on the upper control arm. Has anyone used a camber bolt to bring out and get it back to where it should be?.. thanks for any advice!
AWAR
oregon
03-06 use the bolt you listed, 07+ has different adjustments.
S
SC19
North Carolina
My 07,had the same bolt and caged nut that you showed. The new bolt camber bolt kit is supposed to bring it out but ive never used them before, hopefully it will work.
