Rear end swap
RickBob
Will a rear end out of a 2000 expedition work in a 2002 Eddie Bauer.
whitelightning99
Pa
there should be a tag or tags on the rear cover look the numbers up and it will tell ya what there are
chromehorse
Ontario, Canada
There is also two different sizes of rear diffs. A 9 3/4 and a 8.8 i believe. If you switch sizes your ABS won't work and will illuminate the ABS light.
98eb5.4
s. ontario
includes driveshaft issues then, drums vs discs & lug nut size changed at some point, 12 to 14 mm i think, might want ltd slip, diff gear ratios even 2wd depending on intended use, axle diameters changed for 9.75 ~ 98, trailing arm attachment holes got bigger from 97 -8 etc
lots to sort out before deciding
http://www.fordification.com/tech/rearends_ford14.htm
