Rear Fan Control
David Poelstra
Indianapolis
New to me 2013. I understand climate fan control can be 'given' to rear of console. All fan controls (and fans) work fine under front control. When in 'rear' position, fan blows 'low' and fan switch has no affect in any position 1-4.
Suspected to be fan control switch (1-4 switch and blend control one complete unit), or fuse or ? Does rear fan control have its own blower resistor (separate from front control)? Again, everything works fine from front controls, it's just 'transferring' to rear gives rear no speed control.
D
David Poelstra
Indianapolis
So I solved it. Removed the rear cup holder piece to expose switch housing. Reached down and felt a connector near the back of the switches. Pressed it inward and felt a snap. Now rear controls work. Just a loose connector, and it does indeed work like I thought.
bobmbx
The previous owner probably got tired of the kids screwing around with temp controls.
