Garrett
Is there a way to set the rear hatch to delay before closing, or do you just have to always be swift like a ninja?
Stand to the side of the hatch and stick your arm in the trunk then press the button. It’s inky like 1’ into the trunk, should be able to do that and not have to worry about being hit. Unless you’re a midgetIs there a way to set the rear hatch to delay before closing, or do you just have to always be swift like a ninja?
Oh, well if it’s on the bottom lip than there should be zero issue closing it. #4thgenexpedtionownerproblemsGen 4 has the hatch button on the bottom lip of the hatch itself, not inside the rear like earlier Gens. And...Gen 4 doesn't have the same delay as Gen 3.
I love the hatch mounted button over the stupid interior mounted button that you need to take cover from.
I'm still trying to learn the foot trick that opens and closes the hatch. So far I'e learned that hooking up a trailer the foot thing is great at opening the hatch and slamming it right into your face.
You just described the purpose of the kick-to-close feature.I prefer the interior mounted one with its delay. I can leave the last six pack in there...reach in, hit the button, remove six pack, and be clear before she starts closing. Now I have to have everything in order/in arms before reaching up for the button...not the easiest thing with two arm-loads of brewskis.
My favorite was loading items in the trunk area, and having it close on the back of your head!
If you kick straight up the center, mine opens every time.
The swift move is key here.... in and out, no delay at the top. It took me a couple times before I learned the motion that the sensor desired. Other than the hitch obscuring the sensor occasionally it works every time.Same...one swift kick in and out (no side to side) and it works like a champ. Although I go to the left of the hitch not right up the middle.
I spent at least 5 minutes trying every kind of kick possible the other day and the dang thing wouldn't open. I crawled around underneath and couldn't see a sensor. Then I get home and walk past the trunk and it pops open unexpectedly! Maybe it's just me....The swift move is key here.... in and out, no delay at the top. It took me a couple times before I learned the motion that the sensor desired. Other than the hitch obscuring the sensor occasionally it works every time.
Idk. Just reading what everyone’s experiencing it seems like each sensor is completely different than the next.I spent at least 5 minutes trying every kind of kick possible the other day and the dang thing wouldn't open. I crawled around underneath and couldn't see a sensor. Then I get home and walk past the trunk and it pops open unexpectedly! Maybe it's just me....
