Rear Passenger window is grinding ('03 EB 2WD)
CertusExpo
Customizing trucks since I was 7 with my Legos
Fort Worth, TX
I noticed that the rear passenger window was making a grinding noise when put down but mostly when rolled back up.
I figured it may be some dirt somehow got in the rail of the regulator and just needed to be cleaned and greased.
However, upon disassembly I found that there isn't a traditional regulator but a cable pulley system and he aircraft cable that performs the function of rolling the window up/down has broken strands hence the 'grinding' noise.
Can I simply replace the cable or does the entire power window assembly need to be replaced?
Imgur: The most awesome images on the Internet
robby830
West Palm Beach
Just the cable can be replaced. I did both rear windows recently that had the same problem. Remove the 3 screws from the motor and you can access the cables. I used needle nose pliers to remove the cables from the track pulleys on the top and bottom.
Cables should be just a few bucks at the junkyard. I was fortunate to come across some in good shape.
Sent from my HTC One using Tapatalk
CertusExpo
CertusExpo
Fort Worth, TX
Thank you!
