arbetrader
Hi all, I'm new to expeditions, I'm in the process of purchasing a 2015 Expedition max 4wd (Cdn equiv of EL) and we usually tow with 7-8 occupants (typically 7) plus a 6500lb trailer with about 750lb tongue weight once fully loaded up. It'll be pushing it for sure, but I have a base model XL (SSV) which gives the highest payload, I'm expecting payload to be more than 1500lb as it has no options (no sunroof, or power options).
I just sold my 2008 Toyota Sequoia, it had air suspension and only 1230lb payload, and I wanted something I could beef up the rear a bit with. To my dismay, I just found out that these expeditions have rear coilover struts which completely suck because I cannot put rear airbags in the coil which is what my plan was.
Anyway, I'm still thinking of buying this, picking it up on Friday. I want it to ride as level as possible. I would LOVE some input on this as to options (I have MANY years and miles of towing experience so don't need input about being overweight etc - to me safety/setup is of utmost importance even if the payload sticker is a bit over).
My #1 goal is for it to ride as level as possible.
I use an Anderson EQ hitch. I tend to crank it up a bit after connection, prior to tightening the chains to help with extra weight distr. It worked pretty well for me in the past.
It appears the expeditions sit about 1.5" or so higher in the back than the front, BUT I want to lift the truck slightly too, to clear 32.5-33" tires; say no more than 2" in the front, so I'd like at minimum a 2" spacer for the rear as well; so that it still sits a bit higher. I will always have people in there, and/or tow weight, so I really want the back to always be a bit higher than the front.
What are the best options? If I go Bilstein I'm looking at the 5100 coilovers, can I set the rear slightly higher than the front?
I'm so frustrated after finding out I cannot get airbags for the back. Unless I go with these? They do make them for late model Expys as well. https://www.airbagit.com/Air-Suspension-kits-Rear-axle-p/fbx-r-lin-27.htm
I really want a bit of lift... But don't want to sacrifice rear sag as a result. Need a rear only coil spacer option of about 2-2.5" so I can run my 2" fronts and use these: https://www.amazon.ca/SuperSprings-...springs+ford+expedition&qid=1614803966&sr=8-2
Thoughts on this? I know I'm all over the place. Any of you like the look of a small lift, and still want to tow safely with a large family?
