rear sway bar size
ROCKSBITE
reading, pa
any one know what size sway bar is on a 2000 exp eb with front and rear air leveling? the bushings are worn and the parts store needs to know what size the bar is.
ELVATO
Orlando, FL
Tried searching for it but so far no luck. If all else fails, you could measure it? Measure the circumference with a piece of string, then divide by 3.14 (pi) and that should give you the diameter.
