rear top break lights
popeye
Ladner B.C. Canada
I noticed they were not working so i took off the lens cover and it was full of water, Obviously bulbs shot but the connectors were too any ideas where i can get the connectors {what the bulbs fit into}. Why would it be full of water. Checked the seal for leaks
Hornblaster29
Fort walton beach fl
Mine dose the same not sure how the water is gein in there I just took one of the lights to the part stor an found that som tag lights have the same tipe the fight rite in or u can try a junk yard they shoud be reall cheak to get
FordandPolaris
Saint Cloud, MN
I would see if the vendor Tasca can hook you up with the connectors. If it were full of water, my best guess would still be the seal being bad, or if the plastic cover is cracked somewhere. Unless you had a hole/rust patch in the roof that allowed water in through the electrical inlets, which is really unlikely I would think. I would go ahead and try to replace the seal on the cover, also something Tasca may be able to help with.
