Running boards stopped working
Edwin C Aldredge
Richmond, TX
First day. 30 miles on the truck and the running boards stopped working. They deployed on a lift into a pad, then retracted when they could not open fully (against a rag sobit wouldn’t get scratched.
Fuse shows to be #89 and it is good. Any ideas?
95cobby
Bowling Green, OH
Check instrument cluster options to make sure they are still enabled.. just a guess since my superduty has the option to enable/disable.
E
Edwin C Aldredge
Richmond, TX
That was it!
Checked the dash and the turbo was gone from the display so I went to settings and apparently disconnecting the battery disables the running boards until you re-activate them. PROBLEM SOLVED!
Ed
16plati
VA
That was it!
Ed
Yup same thing happens when you flash a tune, in case you get one
