s 935 e-1 rear passenger axle shaft
albany9044
seattle
I'm trying to find the right axle shaft for my 98 expedition. It has an S 935 E-1 rear end, I've been sold the wrong rear axle shaft twice now and wasted $50 worth of gear oil. The axle shaft has the larger 1.7x diameter. The first shaft I bought had the 1.6 diameter so obviously Iit was too small. The second one I bought was a power torque axk228 which was the correct diameter but it was just barely too short and I found that out when it was literally like 1/16 of an inch too far out for me to drop the C-clip in. I have searched hi and low and can'tseem to find the correct aaxle shaft anywhere. Can anyone help?
Canadian Expy
Toronto ON
are you sure the second one was all the way in, I just replace the rear axle seal on mine and had to make sure the wheel stud heads were not preventing the shaft from going all the way in, I didn't at first so the shaft wasn't all the way in and the c-clip wouldn't go on, check to make sure the head of the studs aren't preventing this
Dbohalls550
