Satellite radio antenna for 2008
pharmerbrad
Missouri
I have a 2008 Expedition EB. I apparently need a new satellite radio antenna (I don't have navigation), since I can no longer get a signal. It's been working for years with my replacement Kenwood stereo, but quit this summer.
The replacement part for my VIN has been discontinued, according to a dealer. Does anyone know if there is a new part number that is an exact replacement? I don't really want a used one since you never know how long it'll work. I prefer to the have the same roof footprint as the original instead of buying a different aftermarket one and sticking something else up there.
Thank you for your input.
Dahammer
Just a curious question- How do you know it's the antenna and not the Kenwood?
P
pharmerbrad
Missouri
I know it's not the Kenwood because the actual satellite tuner is the OEM box which I think is located under the console somewhere. I suppose it could be that box that failed, but have read that it's usually the antenna. I'm not 100% sure, but would like to try the least expensive remedy first.
Gary Waugh
Princeton, TX
On my 08 it was the box that failed not the antenna!! Got a new box from eBay and all was good.. there isn’t much to fail in the antenna, so it’s unlikely to fail!!
sub0cool
Pikeville, Kentucky
Did you figure this out yet? On my 2010, I was able to take loose the headliner and unbolt the antenna. when i did, i used a hair dryer to dry it out and then used silicone to seal around the antenna. Not has a problem since, been about 5 years.
P
pharmerbrad
Missouri
I haven't had a chance to tear into it yet. I'm afraid it's just gonna be trial and error. I haven't found a way to determine which is bad without just replacing one of them.
Gary Waugh
Princeton, TX
That’s how I had to do it! replaced the antenna first (but I thought it would be okay as the ford navigation worked), when nothing changed I got a used tuner box of eBay and after I changed that it all worked perfectly. This forum was great, I had thought the satellite antenna connected directly to my factory radio, I had no idea there was a tuner box located between the antenna and radio!!
