Scary new sound appears after driving 30 miles to work
Manlavi95
PCB, FL
The video captures the sound quite well. I would like to know if the sound increases with RPM, but can't quite tell due to loud exhaust. It's not AC clutch, it's not alternator, it's not the idler pulley... I almost can't locate it. It sounds like it comes from the top of the passenger-side timing cover, but it also sounds like it's coming from the bottom of the timing cover, and it also sounds like it's coming from the transmission. I'm completely stumped. It's the whirring/scraping combo'd with the groaning.
https://www.youtube.com/watch?v=DS098OZc1ug
Bedrck47
Elizebethtown, PA
I haven't listened to the sound but check the PCV valve and hose connection on the passenger side valve cover
Manlavi95
Manlavi95
PCB, FL
Will do, but I do recommend listening to the sound, because it doesn't sound like that sort of problem
JUST4FUN
Admin
Moderator Administrator
Il
it sounds like a timing chain tensioner .
Manlavi95
Manlavi95
PCB, FL
That was my guess. Guessing I should order a whole new timing set. This project shouldn't be too hard should it? I should order a service manual.
What is this timing cover repair sleeve I'm reading about?
JUST4FUN
Admin
Il
not sure about the sleeve. the service manual I think there is a user on here that has them on CD.
Manlavi95
Manlavi95
PCB, FL
I diagnosed better today. Took the belt off, noise disappeared, put belt on, noise is back, took it off, disappeared again. Used the stethoscope and I'm thinking it's the idler pulley bearing and the vibrations induced into the belt. Might also be the water pump.
