Hmmmm...I was considering the SCT from 5 star as well. Wonder if I’d have any issues...2019 Platinum.
The one thing that I am curious is if after a PCM update if the transmission has a smoother shift. I did find a TSB for the F-150s that addresses harsh shifts via a PCM update.
If a PCM update is available for the Expedition it will be strange that the same TSB isn't for the Expedition seeing they are the same engine and transmission that the TSB is for on the F-150.
I do plan to take mine to Ford to see about a PCM update being available or not. Seeing SCM is saying take it to them for such must mean such exist.
But then again you 2019+ guys might be ok as you might already have the PCM update and what SCM built the base tunes against.
Sent from my moto g(7) using Tapatalk
