BAD RONALD
127 K miles on this truck, my wife's daily driver. No skip or misfire whatsoever in Park or Neutral. When accelerating from a complete stop a slight binding is noticeable, kind of like what can be felt during a slow turn in 4wd. The truck shifts normally and there is no shudder at higher speeds.
Posts regarding a shudder, binding, vibration, etc are difficult to compare it's a fact. The closest I have found to the condition I'm experiencing point to a transfer case lubrication problem. Right now I'm planning a fluid change using Motorcraft XL-12. Also gonna do the front diff fluid change while I'm at it. The rear diff change was done 15k miles ago when the axle seals failed.
Anybody have experience with a similar issue?
Will post results on Wednesday to follow up.
