Smoke from new vehicle
J
jonc123
Canada
It has a smell, buy really more like gas. It goes away when it warms up, and still waiting for ambient temperature to really start to go up. I didn’t get a chance to check it last week when it was warmer, but it should be above freezing mid week.
Calidad
California
Have the dealer check the fuel system I know Subaru had several cases of the injectors dumping excessive fuel into the cylinders and customers were reporting smoke at startup. Later engine failure due to fuel dilution of engine oil. Maybe have them test oil for heavy fuel dilution? I think this issue is possible with any fuel system if the injectors or system have an issue.
Soliyou
OK
Mine does the same thing below freezing. Totally fine I guess. Just too much water vapor.
White smoke generally means coolant is being burnt. If coolant level is OK, I would not worry about it. Let it smoke :)
Mlarv
Eastern TN
White smoke in the morning is pretty normal in the cold weather. If you drive it long enough to get the exhaust hot, then shut it down the cold air and the hot exhaust cause water to build up in the muffler and exhaust pipe. When you start it up the water turns to vapor and burns off. I am pretty sure this is what you are seeing. It does have a slight gas smell to it.
