solid axle swap???
828expo
lenoir nc
what all is needed to do a sas (solid axle swap) any info would be great thanks guys
nvycrmn
Springville, IA
a lot. first you need an axle from about 77-79 light duty f250. then you need to clean it all up (grind off existing spring perches), measure to make sure she sits even under the truck, weld on new spring perches, etc....lots of work. i am going to be working on this project hopefully starting this time next year when i move back home to Iowa and have my garage. If you are not very mechanically inclined and good with welding, gonna cost you a pretty penny to get this done. then you have to run wheel adapters in the rear cuz you wont have 5x135 up front anymore...
828expo
lenoir nc
im good with everything but welding lol and my dad is a expert at that lol so im good i jus neeed to know whhat all i need off the doner truck
nvycrmn
Springville, IA
i will try to get you as much info as possible but your best bet would be to join virtualford.org. i started a thread on there on what all is needed for the swap. you can read through it and then ask any questions you may have. there are some very knowledgable guys over there for this type of stuff.
Bart Man
New Jersey
Solid Front Axle
Im just as intrested to do the same! if you have any more info that would be great ! Thanks! :cool:
nvycrmn
Springville, IA
bart, i have been trying to get ahold of my buddy but he has been unavailable lately. I will see what i can find out in the next few weeks.
bledsoejoe
