Solved! Another fuel pump disaster
TN_Explorer
Tennessee
2007 Expedition EL series; 4.6L V-8.
Wife shut it off at school yesterday and it would not start.
Got it home and found no pressure at the fuel rail. Could not hear the fuel pump cycle, so we dropped the tank and found the fuel pump looked good (not burnt). Put 12V to it and the pump spins.
I then put a test light on the pump connector and there is no voltage at Key On. The relay and fuse work; I can hear the relay cycle at Key On. I swapped out with another relay just in case the relay switch was bad, but no change in results.
Anyone ever had an issue like this? I'm stumped, tired and dirty. I did check the inertia switch and it seems OK, but tomorrow I will bypass it and recheck the pump connection.
Thanks for any ideas.
Temple, Georgia
Check for power at fuse 32 and at pin 5 of the fuel pump relay.
  • 25-08.pdf
T
TN_Explorer
Tennessee
I have power at pin 5 and at fuse 32.
Did I check BOTH fuses? No. I was only aware of fuse 32. I'm assuming you mean fuse 71 - I will check it in the morning.
Thank you for the diagram - it helps me understand what's going on.
Bedrck47
Elizebethtown, PA
As stamp suggests
You will need to be looking for 12 V
But you will need to be looking at the meter while someone tries to start the expy
If the expy doesn't start then the voltage will drop
That happens so the fuel pump doesn't continue to pump fuel without the engine running
T
TN_Explorer
Tennessee
OK – here’s the deal. I’ve been fixing stuff a long time, and I don’t usually miss something simple, but this hooked me like a big tuna and reeled me in. I also don’t embarrass easily, so I will tell you what happened.
No power to the fuel pump connector. No power to the inertia switch. The relay worked as it should and the voltage was correct at the power distribution panel. The fuses (#32 and #71) were both good. After disconnecting and reconnecting multiple terminals, voila! – power to the inertia switch! Connected everything back up and yep – the pump cycled and fuel flowed! So we reassembled everything and fired it up.
It threw a code for the evaporative system, and we figured something must have not been connected properly. Shut it off, cleared the codes and it would not start. You guessed it, no power to the inertia switch. #%@@!!!!
Started rechecking – good power to the relay, etc, etc. 12.45V at the battery. On an impulse, I asked the wife to hit the starter. Voltage dropped to 9.4V while it was cranking. You wouldn’t know it listening to it – it did not sound like a dead battery and the engine was spinning at what sounded like normal speed. Hooked up jumper cables and it started right up.
New battery, fires right up, no codes, wife is happy – everybody’s happy (but tired).
In the future I will make sure to check the battery voltage under load. If this story can help someone else avoid a lot of cussing, it was worth it.
The Swagonmaster
High Point, NC
In 40 years I've only seen two cars that did this but it will totally messed with your mind when you find a car that sounds like it is turning over just fine but a new battery makes it start.
inmanlanier
Florida
You obviously know troubleshooting well, and did the right stuff. If I had to guess, you have a bad cell (or even 2) - where they short intermittently. Typically under load the cells will heat up, the plates then move a little - it they touch - boom - a short then loss of that 2.2V per cell. I AM surprised that you did not read voltage at the pump/relay, but thanks for the feedback so I file it in my noggin.
T
TN_Explorer
Tennessee
I have a final update:
This was a weird one. When I bought my parts, the Ford place told me this was unusual, but not unheard of.
Follow along with me as the story did not end with a new battery. It ran fine for 3 days, then died at church. At this point I christened it the Antichrist.
No fuel. One poster was surprised I didn't test voltage at the inertia switch. He's wrong, I checked it many, many times. I even rigged a light that I could see from the driver seat and had power at the inertia switch. No fuel. I was still not convinced it was the fuel pump, but we replaced it and success! - for one day. Now it will start and run for about 2 - 5 minutes and then die. Futzing around back there, I lightly tapped the inertia switch while it was running and it immediately died. AHA! So we found an inertia switch, plugged it in and it ran for another day before stranding us. It has earned it's new name.
OK - follow the trail to the solution. Test light shows power at the inertia switch. In a eureka moment I grabbed a 12V motor and plugged it into the inertia switch. NOTHING. But the test light still works! So, Houston, I have problem between the inertia switch and the fuel pump. It shows 12 volts, but it cannot carry the load.
3rd time's a charm, so down comes the tank. I ran a ground lead directly to the fuel pump and jumpered the power from the existing harness from the inertia switch. Pump runs!! I deduced there is a bad ground either at the fuel pump plug or in the harness.
I got a new inertia switch plug and fuel pump plug from Ford ($80 with my discount - ouch). The plugs came with crimp connectors and high quality heat shrink. I went ahead and soldered everything. While I was at it, I connected an additional ground wire from the pump plug to the chassis. Interestingly, the original plug had crimp connectors on the power and ground leads to the pump, but there were no splices in the fuel tank wires. I finished everything up and it is currently running, although it hasn't regained our trust yet.
I'm hoping this will be my last post in this thread, but the takeaway is -- If you have voltage at your inertia switch but the pump doesn't run, you may want to put a load at the inertia switch to see if you have a bad connection.
Bedrck47
Elizebethtown, PA
Isn't electrical troubleshooting fun? This is what some of us here on the forum go through when trying to help others.
Hope you finally have it fixed
inmanlanier
Florida
Please keep us posted. Yes, ground issues can do very strange things. Way back in the day I built a Cobra replica based on 5.0L Mustang parts. I was smart enough to test each circuit as installed, so when I was done I wouldn't have issues running the car. When I went to run the car, it ran at first crank - I was happy. After putting the body and finishing details, however - no run. For some reason I lost the ground to the ECU, which also was the ground for the EEC IV relay (as I recall the one that powers the computer). Fortunately there was just enough continuity in the "dead" ground leg that as the relay would energize, just the relay coil was too much and it would open circuit, then reconnect, then re-open. With my head close to the relay you could hear it buzz. I didn't even waste time trying to find the open circuit - I simply spliced in another lead and grounded it nearby - voila. All worked.
Can't tell you how many times had to run my own wires. Just not worth the effort and time, to fix what Ford or whoever didn't do right all along. These crazy trucks are a ground nightmare, along with all modern vehicles. Glad to hear you tackled your little devil!
