I write this with the understanding that anyone doing this has a little knowledge on pulling engines, which allows me to not detail every step, only give some advice and lessons learned.
First up, topside
Get rid of the hood. It's quite light, but too bulky for one person without putting it into the windshield.
Next up, PULL the battery, then disconnect the engine harness and finally pull the whole power block off the firewall and put it where the battery was. Pull the heater hoses from the core and intake as soon as you can, which makes access to the intake bolts easier, and they will be in the way later anyhow. Pull the intake, placing the vac line over in the battery spot too. There's 5 bolts on the pass side, 6 on the drivers (10mm), and the whole intake comes off.
Drain the radiator, oil, and power steering. Life is better when it's not in the way and you can reach some of the bolts.
I pulled the lower radiator hose from the radiator. It's a pita, and in hindsight not needed. Pull the hoses from the oil cooler and block and leave it attached to the radiator and pull the whole radiator.
Hint: the fan can be removed with a pipewrench and a hammer if you leave the belt on. Hold the wrench in place with a little pressure and give it some quick raps like you mean it ( on the wrench) until it comes loose.
I disconnected the ps pump lines at the steering gear and return line under the core support, but left the pump on to pull the engine. I would pull the pump next time, and also the oil cooler. The oil cooler can be pulled by putting a couple jambnuts on a 3/8" bolt (IIRC) and putting the head of the bolt into the allen bolt on the cooler, then use a wrench to loosen it. The ac compressor was just unbolted and pulled forward.
You then have to remove the steel heater line in the valley. There are 3 10mm nuts on 2 studs on the rear pass head that must be removed, which allows a harness bracket to be wrestled off. Then remove the lower stud (13mm) and loosen the top a few turns to get the tube to rotate up and pulled out of the rear of the pump. The top 2 trans bolts can come out now. Pay attention to length. There are 2 different length mount bolts. Chase the threads from the front side with a 10mm x 1.5 tap. It's needed to mount the bracket you have to make for the hoist. All that's left up top is the trans dipstick mount (8mm)
Since there is no mount points for a chain to pull the motor, I built a bracket out of some 2in angle iron. I used 2 pieces 6" long and one 24in long and a piece of chain about 28" long. I pulled the waterpump and set a 6 in piece with one leg going down the front of the motor (why you need to pull the pump) and the top leg laying on the top flange of the block. I drilled holes to match the alt mount holes and used the alt bolts there. On the rear, The angle is held up (front and rear are different heights) and holes drilled in the other 6" piece to match up with the trans mount holes. I had the leg face rearward to allow easy access to put the bolts in. In hindsight, the leg should face forward to aid in access to the rear. Also, some metal will have to be ground out on the bottom edge to allow it to sit flat against the back of the block. I then welded the 24" piece to the 2 pieces (corner up) and welded the chain to the side of that right above the 2 6in pieces. The front bolts are the alt bolts and the rear bolts can be obtained from the motor mount plate/block, which need to be removed anyhow.
That's the topside in a nutshell, now the "rest"
