Alan Lloys
I just bought a used 2015 Expedition Limited with the same Sony "premium" system.
I came from a Mountaineer with a system I had modified significantly myself. I also found that the system is pretty poor for an upgraded system.
I listen to all kinds of music and not crazy loud but I do like to have clear, crisp sound with decent bass.
The factory system lacks in the bass as the factory sub hardly makes any sound. If you turn up the bass the front woofers start rattling before you have good bass from the sub.
The front tweeter are of so low quality that they mainly make a sharp hissing noise and doesn't really add to the sound.
Anyway what I did was to replace all the speakers and installed a new subwoofer and amp. Everything I did is pretty much invisible as it just replaced factory components.
I kept the factory subwoofer box but replaced the speaker with a Pioneer shallow mount 8" and installed a 2x175W amplifier with it. I replaced all the door speakers with Pioneer 6"x8" speakers, the front tweeter with Pioneer 3/4" tweeters. This really made a huge difference in the sound. Being able to adjust the sub separately enables you turn the bass down a bit on the door speakers and fill in with the sub.
I did replace the front instrument panel 3.5" speaker as well but this is not really needed for music as it does not contribute much in stereo mode. It is mainly used for Sync and navigation.
The hardest part was to find something to replace the rear 2" surround speakers with. Again not really needed for front seat but since I had everything apart I wanted to upgrade them to improve sound for rear passengers too.
I found that the Sony amp is actually pretty good once you take the subwoofer off it and replace the speakers.
Note that I did replace the front door woofers with full range speakers which meant that the treble was a little too much. I found the sound to be better by just turning treble down 2 notches as opposed to disabling the extra tweeter in the door speaker.
Here are the the components I used:
Door speakers (all 4): Pioneer TS-D6802R
Front Tweeters: Pioneer TS-T15
Subwoofer: Pioneer TS-SW2002D2
Amplifier: Soundstream PN2.350D
These replacements items will make a major upgrade to your system without breaking the bank. I think I spent around $ 400 including fuse holder and install hardware.
The optional changes I made to the front center speaker and rear speakers (which are actually a center speaker and not even in stereo) were:
Front center: Pioneer TS-A878
Rear surround speakers: Peerless 830983
Hope this helps.
Hope this helps.
