How do you change your display between mpgs and such?The buttons have to be somewhere
Make sure all doors are closed. Turn ignition to ON but dont start. Push the button below the speedometer a few times until you get to "HOLD RESET FOR SETUP MENU". Hold the button a few moments and let go when the screen changes to "HOLD RESET FOR SYSTEM CHECK". Press and release the button one time. Screen should now say Oil Life 0%. You will then see you need to hold the button again for a few moments to reset. Should say Oil Life set to 100% when completed.
