Stable-eye-er
KWT2000
NINE MILE FALLS
place frame bracket on passenger side, bracket has a large hole to locate over the lower control arm bolt, install the 2 bolts it exsisting holes,
place the shock into the bracket and install the nut leaving it loose.
slide shock out about half way to position the other bracket on the steering linkage
install this bracket with the supplied u bolts
tighten every thing up and check that you can turn lock to lock
adjustment may be required..
i have pictures in my album of mine installed
nvycrmn
Springville, IA
make sure when you order it, if you have a lift, you tell them. this will supply you with a different bracket. i did not so i had to drill mine out a little to make it fit. and yes, make sure you only pull the arm out about half way, because if you dont, when you turn to full lock, you will bend the bracket. trust me, i am speaking from experience! hahha
nvycrmn
Springville, IA
it did initially, but the new wobble was due to something else. never did figure it out. changed idler arm and it still wobbled, but now it is gone. need to reinstall stabilizer tomorrow. steering feels loose without it.
KWT2000
NINE MILE FALLS
i agree i bent mine a while back and it was off for about a week while the new one was on its way... i didn't got above 40 for anything just didn't like how it felt
nvycrmn
Springville, IA
completely different handling over bumps and whatnot. never noticed it before but when i took mine off...wow. goin back on tomorrow for sure!
