98 5.4
So yesterday I went to start it up and turned the key and it clicked once did not start. Tried again and it started up no problem. Drove it around with multiple stops so I was starting it a few times and had no issues. I go out this morning to try and start it and nothing but a single click every time. Interior lights worked, radio worked, etc. Seemed like all normal power but would not start and the battery gauge on the instrument panel was in the normal spot. (I did not test the battery to see what the volts were at, I should of) But it would not start. It was like the battery was dead. So I charged up the battery and it started up no problem. I live in Michigan and past couple weeks of below zero weather we had it had no issues firing up. Anyone have any input thinking something may be draining the battery every so slightly that it does not have enough power to start it?
The neg and pos cables are clean, the terminal connections are new as of July 2017 and the battery terminal posts are clean as well. The connections there are all good not loose or anything.
Battery is new as of January 2017
Starter Relay new July 2017
Alternator new July 2017
