Hello everyone, my name is Edwin. I have a big problem with my expedition. It turns on, but when I try to shut it off it stays on. I turn the key and it stays on. I have to take a fuse out of the engine to shut it off. It all started about two weeks ago. Mansoon hit here in Phoenix and I got stuck in traffic, so I had to drive in two feet of water. I made it home fine. The next day car wouldn't start. I got a new battery and it turned on, but the gauges were going crazy. It had a short so I had a total of 5 so called mechanics take a look. Neither of which figured out the issue. One said it was my fuel pump and to get an electrical mechanic. The rest said it was my computer. Finally a 6th mechanic said to replace my alternator and looked under the dash and found my remote keyless module smelled burt and it did have a small short.
Now I replaced the alternator, new battery, and got a used remote keyless module (not sure if its supposed to be the same model#). I also changed the the little white box I think it's called the ignition starter switch. What do I do now.
Issues:
1.starts, but won't turn off
2. Drives, but I feel it has less power push gas pedal all the way down it hits 30 or 40 mph.
3. Lights inside don't turn on when I open door.
4. Ac in back passenger won't turn on just the front works.
5. I feel like something stays on the fuse box relays get very hot (don't know if its normal)
6. It shakes a little more than before.
Please help me. I would like to try and fix it myself. I am very tight on cash to take to a shop.
Issues:
