Steering wheel loose?
GaryB
Atlanta GA
ok, I've been chasing a sound feeling for a week or so now. When I turn the wheel, once in a while I hear a click. I can feel it in the wheel. I thought it may be the u joints in the column, but when I parked it after work, I realized that you can push (not rotate) the wheel left to right about 1/8" if you try. When you do, you hear the noise I've been hearing. What could cause this? Is it normal with these vehicles?
richs fishes
Long Island, NY
I had a weird sort of "clicking" noise from the steering wheel. Also had a bit of play that sort of seemed like worn out tie rod ends. Changing out the lower steering shaft with the u-joints fixed all that for me.
Bill Schmidt
Omaha, NE
I just got the expedition 187K miles and dont know the maint history. I have noticed that slight click or gap in the steering at times. I'll try it sitting still.
Is this the part you fixed?
pic:
Bill Schmidt
Omaha, NE
I remembered to test this sitting still and its firm no tick or click. I only notice the slight tick or click in the steering wheel every once in a while while driving and turning the wheel.
richs fishes
Long Island, NY
Its probably the u-joint starting to seize up. Once I took my shaft out I was amazed how bad the u-joints really were. One of them could not be moved by hand! Amazed it didnt feel worse when turning the steering wheel.
Bill Schmidt
Omaha, NE
OK I finally figured out the sound. The steering wheel has some vertical play in it. Sitting still I can move the steering wheel up and down (toward the roof toward the floor to be perfectly clear) it only move like a 1/16" and make the slight tick sound.
it does not do it turning the wheel only exerting force toward roof or floor.
any concern?
bobmbx
any concern?
Can you tell if the wheel is moving on the steering shaft, or is the tilt assembly moving as a whole?
