Stereo problem after boosting mistake
irishinontario
Brantford, ON
A few weeks back my idiot neighbour attached booster cables incorrectlyrics to HIS donor van.
I changed the battery that evening, but my after market stereo hasn't worked since.
That morning my 4x4 light would flash, but not since the battery change out.
The stereo/DVD seem to be the only things not working.
I checked all the fuses that refer to radio in my manual
Any other suggestions?
Thanks
stamp11127
Temple, Georgia
I would expect the reverse polarity blew something in the radio. Fix or replace.
Verify you have voltage to the radio before condemning it.
dev199505
US
Your stereo should have a fuse is on it that might have popped
Sent from my 5054N using Tapatalk
I
irishinontario
Brantford, ON
I'm trying to find what fuse it would need but no luck.
ANY ideas where I would look up? It's not on the jvc site
Thanks
dev199505
US
It'd be on the back of the stereo near the plug or itll be inline on the power (yellow) wire
dev199505
US
It is an aftermarket unit correct? What model number?
I
irishinontario
Brantford, ON
Still nothing
I even wired up a different stereo bit it didn't even light up
Could there be a fuse under the hood or a second fuse that involves the stereo?
Thanks
stamp11127
Temple, Georgia
How did you check the fuses when the problem first occurred? Eyeball, test light or meter?
