rmzsuzuki89
you may want to consider dropping the front. even with beefing up the rear, its still gonna sit lower so why not compensate with drop springs up front AFTER you fix the rear. Have you considered air bags for the rear? I know I have seen them on F250s to help with towing and heavy loads, just not sure what they are rated for. also the independent rear suspension is a limitation as compared to solid axle. Bottom line...this may not be a cheap fix.
That's not good lol...And I may drop the front if the back still sags a little when I get it right.
Would I have a tank, or just a compressor for air bags?
