Stock backup cam with aftermarket HU?
Yoop33
St. Orlampawaterton Islands, Florida
Has anyone done this and how?
I just ordered a Kenwood media HU with camera capability but apparently, there is no option to add or use the stock backup camera system. Has anyone rigged up a solution?
Thanks
Aspen03
Indianapolis
In order to use the stock camera you will need to splice on an RCA connector to hook up to the new HU. Frequently the White/Green wire is the + which will go to the center pin of the RCA and Brown/Violet will be the - going to the outer shield. What year and audio system did your vehicle come with?
You may need to run an acc wire for radio turn on if its controlled through CAN
