Stuck Rear Hub Assembly
Marksfps
Georgia
Hey everyone!
I have a 2006 expedition 4x4.
The rear hub needs replacing.
I used a puller to try and get the hub off, it broke the spindle loose, the shaft is fully loose from the hub. But the outside of the hub is seized pretty hard. I am using the puller to tighten further trying to break it free, but it is pushing the CV axle back into to differential. I start to hear tiny little popping noises or creaking if I tighten too much. Am I in danger of damaging the CV shaft or diff if I keep tightening till the hub comes loose?
I have an oxy acetylene torch but I haven't tried it yet. I've beat on this thing till I'm worn out. Any ideas? Can I keep tightening on the puller pushing that CV back until the hub breaks free? I've tried hitting it while under pressure, that doesn't work. If I heat it up do I heat up the outside part and not the hub assembly?
Hope all this makes sense. Thanks in advance!!
Trainmaster
Old School Member
Rockaway Beach, NY
Sorry you haven't gotten an answer yet. I've had a heck of a time getting front hubs out, but I don't think I'd press against the axle, for fear of damaging the CV joint. Not sure, and can't offer much more.
Look on the F-150 forums. They have more do-it-yourself mechanics and are more common.
I spray, heat and beat over and over and over again. Possibly insert longer retaining bolts through the back and beat against them if you can get room?
Or put the rotor back on and beat it from the other side using a 20 lb sledge via a 7-foot long pipe.
Yukon Joe
Oak Island, NC
Hey everyone!
Maybe this will help?
@Yukon Joe
Slide hammers go over the studs of an axle, then lug nuts hold it on. They are the best bet for removing items that are either stuck or press on fit. We used to use them on motorcycles all the time. Their were ones made for removing stators, Magneto's, etc, and most were threaded with that size. Usually anywhere from 14 mm to 22mm. Automotive and truck slides are either a flange type like the hub puller, or some use 3 fingers to hook behind an item to be yanked.
MrDoc
I had to heat it, then slide hammer popped it off.
Thanks everyone!
Hate to hijack a thread but I'm in the middle of this job in the cold in the driveway and the sun is starting to set.
Where did you heat it? I'm using a map torch and slide hammer and can't.get.it to budge. Hate to think I'm going to have to take it.to Firestone in the morning where they won't use my timken hub and will charge me an outrageous amount of money.
M
Marksfps
Georgia
I heated very carefully on the left and right sides of the outer housing. I didn't heat till it got red, I used a temp gun and stayed under 500 degrees, then it popped right off.
Sent from my VS996 using Tapatalk
M
Marksfps
Georgia
Here is a picture. I heated on the front of the guard and on the back where most of the meat of the metal is. e35088ccd0efedb4c85ae20c9d25a261.jpg
Spray it again, we posted a list of your best penetrating oils. Liquid wrench was one of the best for money. Is that a slide hammer flange puller in pic? A big slide hammer one works best. Do you have access to gas/acetylene torch? That would help. Propane ones don't get hot enough. It looks pretty rusty in that pic. How set up is your shop for this job?
M
Marksfps
Georgia
This was a reply to Mrdoc.
This pc is the result, I used my oxy acetylene torch to heat it up slightly and the slide hammer attached to pull it off. Just the slide hammer was no good.
This pic is after the bearing came off.
That's what I thought. A hot torch usually works the best. Problem is the op needs to be careful. Keep an ABC extinguisher handy just in case. Concentrate your heat, and don't over do it. Also this shouldn't need repeating but heat in a well ventilated area, away from any fuels, or explosives. Safety is Paramount. We want you guys back after Christmas!
