Tony@MTVA
I am having the same problem many are having with water leaking from the front drivers grab handle. I understand the drain tube runs down this A pillar but what I don't understand is if the drain tube is clogged as so many post have indicated how could that cause water to leak from the grab handle. Also if the drain tube has come loose from the nipple that connects it to the sunroof it would seem that my headliner would be getting wet. It is not and the drain channel in the sunroof is perfectly dry and actually has dust in it so I am trying to understand where the water is coming from that is leaking from the grab handle. How do you pull the molding off the front drivers pillar and if I do this can the drain tube be accessed and inspected. Thanks for any replies.
