Synch 3 Wifi update
bobmbx
For those that installed 3.0, have you noticed any difference? I've noticed some icon and text font differences, but one change is now bugging the crap out of me.
When my HVAC is in auto (which virtually all the time), the fan now blows through the defrost vents all the time at an increased rate, which means its louder. Its not at max fan speed, and it does vary if change the temp, but its always there. It didn't do that before the update. And the system works fine, meaning I can still control manually where the air comes out. Bottom line is...my fan now runs at a higher speed while in auto.
Otherwise, I haven't noticed anything.
ExpeditionAndy
Fort Wayne, Indiana
Mine finished updating tonight. I used a 16GB flash drive and it worked fine. It told me that it was finished updating and to remove the stick so it could reboot which it did, but it never gave me the .XML file so I'm stuck not being able to show Ford that it updated.
My 32GB Scandisk Extreme USB drive came in today; halfway through loading the software on the drive it reported an error. Now I can't delete what's on it, it will not format, it keeps saying there is an error with the drive. The drive is going back tomorrow for a refund. I still don't know how to report to Ford that I now have V3.0.
mossback
2017 Limited EL
WA state
I’m pretty sure that if you attempt a Wi-Fi update that process will indicate/update the Ford server that you have the latest software installed.
East-TN
Air Force
TN
+1...the Wi-Fi connection will report back to Ford you've updated your system. After you connect to Wi-Fi for 20 minutes or so, give it a couple of days before it will show the update on Ford's Owner website. Both my Expy and Mustang did this.
East-TN
Air Force
TN
I noticed this yesterday as well...thought I was getting senile (still may be), but it did seem to be a little louder than before....weird.
chuck s
Instructions state any flash drive must be completely reformatted (not quick formatted) and the format is specified. Your computer may default to different format.
There are several methods to fix or reformat a "bad" flash drive.
-- Chuck
ExpeditionAndy
Fort Wayne, Indiana
Do I have to leave the truck running for 20 minutes to update?
ExpeditionAndy
Fort Wayne, Indiana
I keep mine on Auto too. I really didn't notice this when I went to breakfast this morning. I'll try to see if I notice a difference.
Bigbadbull
Hoover Al
So I tried to manually search for the update via WIFI , and it is still not showing up.
Current software is the same as when the dealer re flashed it in DEC. v2.3
ExpeditionAndy
Fort Wayne, Indiana
-- Chuck
Chuck what are the methods to fix a bad flash drive. I'll try them before I send it back. I did the full format for the exFAT. I've tried using the command window and dos to delete the files it let me do it but then when I looked at them in windows, all of the files were back. I keep getting I/O errors so I think the drive is bad.
bobmbx
To get the major updates, like 2.3 and 3.0, you must use the thumbdrive method. It will not update via Wi-Fi.
I don't know exactly what the WiFi update feature actually updates, but I've seen it working.
bobmbx
Micro disks have a common problem that results in the file system being "locked", and turns itself into a brick. I've had 2 Sandisc 32Gb Micro SD cards lock.
Here is a helpful link. There's not much you can do, though. At least you haven't lost any data. https://www.remosoftware.com/info/fix-error-sandisk-sd-card-wont-format-windows
ExpeditionAndy
Fort Wayne, Indiana
East-TN
Air Force
TN
Not quite accurate...you can update to 2.3 or 3.0 via Wi-Fi, but it seems hit or miss. USB is definitely the best/most efficient way to update.
NorthGeorgia
United States
I am still wondering why the instructions seem to imply that the vehicle needs to be 'running'? I did the last one with the Expedition in the 'ON' position but engine not running. Is this the way most of you do it....too.?
LokiWolf
Moderator
Richmond VA
In theory it will work over Wifi, but does seem hit or miss, and depends on many stars aligning. Go to the Ford Owner site and download it. Follow Ford's instructions, and you should be good to go.
LokiWolf
Moderator
Richmond VA
I do a combo, start the truck and get it started, turn off the motor and back to “On” without opening the door. I sit and play mindless games on my phone, or watch YouTube on my iPad, if cold I might start it back up. If I am driving a good distance and don’t need Nav I will do it then.
Running is better, because unless you have upped the timeout via FORScan, you could have the unit turn off. My timeout is much longer than stock, so no issue there.
chuck s
The instructions specify (not imply :) ) to leave the vehicle running but others report success just Ignition On. Good instructions are designed to be failsafe, hence leave it running. I did most of my update running back from errands and only a few minutes idling.
Now I gotta get out Forscan and reset the "keypad access while driving" or whatever it's called.
-- Chuck
