Prince_Polaris
Here's a pic of a factory '03 Expy EB key FOB: Notice the rear window blue button has a SUV-like vehicle on it ....
The battery can be killed if the rear wiper motor is bad or too weak (or wiper shaft is seized....) to "park" the wiper. It will continue to draw power until it reaches the "park" position. The washer fluid to the rear window is supplied by the same pump motor that supplies the front windshield. So all you are confirming is that the rear washer electrical circuit is functioning (along with the single washer pump...). Meaning, the rear wiper/washer circuitry is functioning correctly. The rear wiper motor can be dorked up, but at least the circuitry is intact. To keep from killing the battery you would need to pull the rear wiper fuse, until you can replace the rear wiper motor or latch/wiper shaft assembly.
https://www.amazon.com/Ford-6L1z17c426a-Hatch-Glass-Striker/dp/B009JMCXE6#customerReviews
-snip-
Thanks, that's good to know! I'll keep the remote with the hatch button then, and that means the circuitry is okay, the wiper just needs lubed.
My dad drives past the dealership on his way to work every day, and he said today it was gone, so they must be repairing the wiper now. Or it's been sold, in which case I suppose it wasn't meant to be.
Y'all don't think the wiper motor could've burned itself out, right...?
