Timberline Owners Question - BO center speaker cover
KetMalice
Oklahoma
Is your center speaker cover “wavy”? Basically it looks like it’s flimsy plastic and only has 3 anchor points. It rattles because it’s not really secure. They replaced it once already, this one is a lot better than the original one.
It’s much different than the B&O on the raptor and basically every other ford center dash speaker I saw on a lot. All of those it looks good and everything is straight/even/flush.
2020FordRaptor
Nevada
That is warped.
LazSlate
Arizona
The design will always be problematic as that area sits right in the sun. I have not looked but maybe it can be removed and some THIN double sided 3m tape be placed around to secure it.
Rob6805
Yep, that looks like crap. Don't put up with it. These are $$$ vehicles.
smstroben
Lakeside, CA
This was discussed in another thread a few months ago where multiple people posted pictures with the same issue. My 2022 303A Max looks the same as yours. This photo was taken the day it arrived at the dealer. It was built on 6/16 and was delivered on 7/11, so it didn't sit in the sun long. I don't believe its gotten any worse over the the past 4 months. My take is it's a design flaw and not a material quality issue.
CDNRabbit
Ontario Canada
Has anyone had it replaced? Always helpful to know there's a solution because causing a fuss.
K
KetMalice
Oklahoma
Yes the picture I posted was the same day I picked it up from the dealer after they replaced it. It’s a design flaw I’m assuming.
TimberExpy
Florida
Mine is like this too. What I find more annoying is the seam where the dash meets the instrument cluster, behind the steering wheel. It looks like it needs to be "snapped" together better, but it won't. Has a slight gap on one side.
CDNRabbit
Ontario Canada
@TimberExpy yup same issue on mine. I doubt it's an easy fixed, the bezel is tight in the middle and open almost 1/8" in both corners. Looks like a bad mould and/or needs a connection point right in the corner.16681114128086494079213954537008.jpg
TimberExpy
Florida
@TimberExpy yup same issue on mine. I doubt it's an easy fixed, the bezel is tight in the middle and open almost 1/8" in both corners. Looks like a bad mould and/or needs a connection point right in the corner.View attachment 75574
I have had the oil changed on this thing twice now (actually 3 times) and I keep forgetting to mention it to them. I am hoping that if anyone gets this fixed or at least looked at, or the other issue with the center speaker, that they report back here what the result was.
dhenderz
Had mine replaced under warranty. Waste of time. Replacement, which took nearly 2mos to get, looks nearly identical to the original one.
rd618
new york
Odd. But mine is the same. The replacement was also the same. I just left it and think that it was intended to look like that. I don’t really think it was. But helps me sleep at night.
CDNRabbit
Ontario Canada
Took the cover off today. There is nothing in the center to hold it down. I'll probably add a reinforcing styrene strip along the edge next time I feel motivated.
TimberExpy
Florida
Well I guess there is some comfort in knowing that the new replacement is the same as the original… makes me think it’s supposed to be “wavy” like this.
RacerBX1
SE Michigan
My 2023 Timberline (picked up Dec 2022), like others came with the warped Center Channel Grill. I took it in for service and warranty work, one of the warranty items was the center channel grill warped. It was replaced and the new one is not warped at all. Not sure if new design, better quality or something else was used but it looks good. So, it’s worth a shot to get it warranty replaced if you’re not happy with the wavy one.
