Tire Question
MPMajorMike
Burke, VA
I have a 2003 Expedition and would like to purchase the Nitto Terra Grappler with either 17" or 18" wheels. What is the largest tire size I can purchase without any modifications to my Expedition? I am looking at purchasing one of the following.
285/60R-18
285/65R-18
285/70R-17
295/70R-17
325/60R-18
Thanks!
Mike
chrmar
Saint John, NB
Look on your door jamb for the factory tire size sticker. You can then go here to figure out the equivalent rolling radius.
For my 97 Expedition, the factory tire size is 255/70R16. The "plus one" concept states that for going up in rim size, you should add 20 to the width and subtract 10 from the sidewall height. However, I did some playing with the calculator there and discovered that for my sizes that doesn't quite apply...
255/70R16 = 275/60R17 = 295/55R18
YMMV
M
MPMajorMike
Burke, VA
I know that my stock 03 Expedition's tire size is 270/70R-17, but I wanted to see what the largest Nitto Terra Grappler was I could fit.
Anyone have an 03' or equiv. with these tires who can provide any advice?
KWT2000
NINE MILE FALLS
With a 3" body lift, spring spacers in the rear and the torsion twist keys what is the biggest tire i can run??? im running 295/70/17 with no mods i would like to go to 325/75/16 or even 325/80/16 any input is great thanks
Lane24
technical advisor
Alberta , Canada
I have 315/75/16's with no problems, and the set up you described. I am running themon 16 x 8 rims with 4.5 backspacing.
rptr00
Las Vegas
I have an 04 2WD and was running 275 60 20 (32.99) with no problems.
