Tires or a transfer case?
berndog24
Arizona
I have a 2000 Ford Expy XLT AWD. Recently I went on a trip into the central Arizona mountains towing my Kawasaki Teryx. I had been hearing quite a bit of rumble from the front end that I now know was a bad tire as my friend pointed out when I arrived. I bought 2 new tires and the rumble was gone. Unfortunately now it makes a howling kind of sound when accelerating. I towed my toy about 175 miles home in 100+ degrees with no problems other than the noise. I'm pretty sure (but not positive) that noise was not present before the new tires went on. I'm thinking it's because I didn't get 4 new tires. The new ones are the same size but they are not the same brand. I read in another forum that something like this ocassionally happens when installing the spare.I don't want to throw money at 2 more new tires if I need to put it into a transfer case. Also don't want to put it into a TC if it's tires. I'm leaning towards tires since I never noticed the howl before purchasing the new front tires. Any thoughts on this or has anyone experienced this? Thanks ahead of time for any info anyone posts here.
B
berndog24
Arizona
Well, what I read on this other forum was that if the tires are slightly different diameter it tricks the computer into thinking there's tire spin and kicks in the 4wd intermittently. I haven't heard of this but my experience with AWD and 4wd are basically nill so I'm looking at every possibility. I should add that this howl is only under a load and goes away on steady throttle. There is no slipping as far as I can tell so I'm not thinking it's a transmission issue. I'm pretty sure this started when I replaced the front tires.
B
bedrck46
Just a thought but have you tried switching the fronts to the rear and the rears to the front to see if the howl sounds like it has changed any
KWT2000
NINE MILE FALLS
explorers use a viscous coupler in there awd system where the expeditions dont so i doubt it is the t case,
what brand and type of tires did you put on and what did you take off
