JonnyQball79
what is the year of your expy and what size are you running now![]()
its stock size for 2001 think its 265/75/16
i was running 295/70/17 on stock height with no rubbing... so you should be able to get 285/75/16 under there or maybe 295's
Ok but did it mess with your ABS system?? The guy is claiming going any bigger will mess up my ABS.
running bigger tires will not mess with your abs it will make your speedo off a little bit but the only thing that can mess up the abs is running bigger tires on the rear than the front
