Torsion Bar ?'s
masterhacker
Wisconsin
SO i called ford about ordering the 7700 Tbars part #F75Z-5B326-KB and they told me that the F75Z-5B326-Gb is the same they said they are both code 7 (dont know what that means). can anyone confirm this, I dont want to shell out $250+ and end up with the wrong parts amd have to re-order them
and also the air ride expy have the same length tbar as the standard susp correct?
Thermo
technical advisor
Master, I can not confirm the "code 7" aspect of things, but the air ride and standard Expy's have the same length torsion bars. The only difference is the spring rate of the bars.
FloorIt
Albuquerque, NM
the keys are the same too right? so everything will swap over?
You can use the keys you have now. The bars are the same lenght, the only difference is the stiffness of the bars. I replaced mine when I did my lift and remove my air supension.
