TPMS Sensors?- G2 Expedition, G3 wheels
kmh1596
MA
In the near future, I'll be upgrading the rims/tires on my 04 EB Expy to newer ford rims/tires, likely 20s. My question is this: Am I able to program the newer style sensors (bands and sensors) to my old system on the 04, which would typically have the valve-stem mounted sensors?
Thanks!
sgtowing
Supporting Members
Valrico, Fl
I put 18" 2010 f150 wheels on mine and they would not work. The newer wheels did not have the band type sensors in them. I wound up having to put the old sensors in the new wheels. It all works just fine.
Sent from my Galaxy SIII Using Tapatalk2
K
kmh1596
MA
Thanks for the response. To move things to the newer style, would the old truck accept the bands and sensors, and program to them?
Newport News, VA
Use the old sensors...I have had them in 24 and now 26 inch rims...no probs
Sent from my BlackBerry 9810 using Tapatalk
K
kmh1596
MA
Will the valve style sensors definitely fit into 2012 fx4 wheels? Need to be sure before buying this set I found on Craigslist.
Thanks!
Newport News, VA
try the Ford Customer Service on here...they have a thread and they may be able to answer this question
K
kmh1596
MA
Hi Cory,
Thanks in advance for your help! I have a new set of 2012 TPMS sensors already installed in the wheels i'm putting on the truck--If you could check with them as to whether or not those sensors could be programmed to the 04 Expedition, that'd be awesome too.
Thanks!
Kevin
FordCustSrvc
Dearborn, MI
Hi Cory,
Thanks in advance for your help!...
You’re welcome, Kevin. My adviser said you can’t use the newer style sensors with an older vehicle; they aren’t compatible. The 2012MY F-Series rims use a valve stem style sensor, but it’s a different style then what was used on the 2004MY Expedition.
Cory
K
kmh1596
MA
Thanks, Cory!
Can your advisor confirm that the 2004 style sensors will for into the 2012 fx4 wheels? I bought them, so I'm hoping the sensors will move over!
Does it make sense to move over the original sensors (likely original to 2004, and 8years old) to the new wheels, or would it be best to buy new ones? I will be getting rid of the factory 17s anyways.
sgtowing
Supporting Members
Valrico, Fl
If your not having problems with the old ones, I would switch them over.
Newport News, VA
yes it makes sense...i have an 04 EB and i took my factory sensors and but them in my 24 inch rims...no probs...now i have them in 26 inch rims...NO PROBS...no need to buy new ones
Newport News, VA
make sure they get put on the truck in the same position...front right sensor gets put in new rims on the front right...and you wont have to worry about anything getting programmed
FordCustSrvc
Dearborn, MI
Thanks, Cory!
Can your advisor confirm that the 2004 style sensors will for into the 2012 fx4 wheels?...
If your not having problems with the old ones, I would switch them over...
I sent another note to my adviser, guys. :popcorn:
Edit: He said the parts weren’t designed to fit together, so he wouldn’t be able to confirm if they would work or not.
Cory
Newport News, VA
Though that's the easy fix...I like the feature working to know when my tires are low...especially having 22s on wife car and 26s on the expedition
Mr. 10K
