kingpolaris
The outside temp display works (95F all ready - flm). i also pulled the sensor and checked the ohms last night, room temp and in a glass of ice - ohms matched specs.
dual zones with digital climat control.
i do have an obd scanner (innova 3100) which is currently flashing a p0356. i think i can download a ford specific program for it, is it worth getting?
could the pcm be bad? im working on the p0356 code right now and i have found that coil #6 has a resistance reading 10x's of the others on the input conector from the pcm at the coil and i cannot find any shorts in the wire harness. i ohmed out the ignition coils and all seem good (coil circuit complete/closed). i read somewhere that bad coils can kill drivers in the pcm. could a this be my problem? i jumping back on the ford to dig more into the harnees now to look for shorts.
thanks and any other advise would be great.
Ok, thanks. That does clear things up a bit more, and it's easier to advice when we know a little more about the background and of course your own abilities and qualifications. I have similar qualifications myself when it comes to HVAC systems.
That said, there are no WOT switch, this is determined by the PCM based on the TPS. What may be the cause for compressor not engaging is if the PCM thinks it's too cold outside, does the outside air temp display work? That sensor is located in front of the condenser, behind the front grille. What type of AC unit do you have? The digital climate control with dual zones, or the standard manual control with manual fan and temp selector?
EDIT: On a side note, do you have any sort of diagnostic OBD scanner? Like the OBDLink MX? If you do, you can download FORScan for Windows, which gives you almost the same access to read data PID's as the dealer has with their scantool.
