kingpolaris
Ok, I'm don't consider myself an a/c newb but this rig is kicking my ass.
2003 Expedition Eddie Bauer
A/C kicks on as soon as i start the vehicle but only stays on for about 5 seconds. Refrigerant pressures are low (i tried jumping out the low pressure switch) but shouldn't the compressor cycle back on after the pressure comes up - like ever other car i have ever worked on. I've checked high and low side pressure switches, interior and exterior air temp sensors, clutch relay and diode and all are good. The only way i can get the a/c to stay on is to jump out the compressor relay located behind the lh headlight. the only thing i can think of is it might have a bad WOT switch (wherever that is), a bad coolant temperature switch (again, wherever that is) or the dreaded bad pcm?
I'm running out of things to check so any advise would be awesome.
Thanks!
Thanks!
