trys to die at stop light
01ExpyOwner
california
i have a 01 expy 5.4l xlt 2wd 235k-ish, it has code p0420 and p0442, bad cat bank one and hole in evap system, my problem is every once in while when stopped at a light, it will try it die, i would have to give it a little gas (not to much when im behind someone), also i think my gas gauge is off i acts like its out of gas at a quarter and tops off at above F, could either code cause this?
all help appreciated
1997SCEBFEX
Northwest Panhandle
any recent maintenance; or do you have maintenance due/past due other than what you've identified?
Quick hits:
* IAC replace/clean
* Fuel Filter
* Air filter
* MAF Dirty
* Vacuum leak/s
* PCV valve/line
those codes surely aren't good and can exacerbate any condition as the PCM tries to compensate.
Biggest one is find and fix any vacuum, or exaust leaks first. Anytime you have a lean Condition on newer vehicles, the computer tries to compensate, not good. You will plug up cats eventually, very expensive fix. So jump on the leaks now.
01ExpyOwner
california
im wanting to do a tune up and oil change but that might have to wait due to Christmas gifts, i'll need to save a little more before anything major, hopefully it's a easy fix, would a bad torque converter cause it to try to stall?
TobyU
Ohio
That evap code if gross leak is prob a lot of it.
Look listed for vacuum leaks. Take a 3 foot long piece of 3/8 fuel line and put on end in you ear and hold the open end around the engine at places to hear leaks.
The evap line of of fuel tank often causes this type of code. Get under it and look for rotted off or spongy areas.
It goes all the way up to the evap charcoal container thing. I think it's in one of the front fenders on an 01 maybe behind headlight.
The pcv hose in valve cover and that line loves to deteriorate on those and there is a rubber elbow on back of intake that does the same and will cause all kinds of lean mixture and idle surging.
Listen for those with the hose and feel around them too.
TobyU
Ohio
That's a nice one there. I don't have a smoke machine yet. I can rig one if I have too but have been able to hear them so far.
TobyU
Ohio
hey would a bad o2 sensor cause bad cat code?
Rarely. If you're talking about a ln 0420 or 0430 code for catalyst is below threshold efficiency... it's rarely an oxygen sensor. Usually a sensor is just fine and doing its job and just reporting back the conditions that are out of spec.
These two are usually caused my ignition misses, unburnt fuel, or burning oil.
Sometimes the converter has been damaged a little bit and is weak other times it is fine. If you have occasional random misfires from the coils and plugs not being in the best of shape then the unburnt fuel will prevent the converter from cleaning up and making the mixture as clean as it should be when the second O2 sensor senses it.
You can use a scan tool to check for test results and see the misfire counts for each cylinder to see if the cylinders on bank 1 or bank 2 coincide with the converter code you're getting for Bank 1 or bank 2. Remember Ford bank one his passenger side unlike other brands.
Sometimes coils and plugs will solve the problem and the converter code won't come back. Other times it will sometimes it takes a month or more. At least it has for mine on some cars taking a long time to pop back up. But it will not make the car run badly at all. The converter code itself will not make the car run badly and you won't even be able to tell if there's any running issues but, sometimes certain things causing the converter code to pop in the first place will make the engine run rough or miss.
TobyU
Ohio
I just reread your original post. You've got to get the large vacuum leak fixed first because with a vacuum leak the engine richens the mixture trying to make up for it and there's extra fuel that can be unburnt causing your cat code.
Get the vacuum leaks slow down to a minimum then clear and recheck codes. Then I would check for misfire accounts and feel if you have any shaking your vibration at all of the engine with it in drive with your foot on the brake.
The EVAP leak or any other vacuum leaks are going to cause it to run poorly and get worse gas mileage.
johnboneske
Ohio
I strongly doubt it's an O2 sensor. Why not figure out the cheapest fix first, which is a vacuum leak, yes you need a smoke machine but after that it cost a few dollars for some rubber hose. You have had other codes as I remember, it all points to vacuum lines. Once it is fixed, it will smooth out at idle, won't want to quit, etc. A bad O2 sensor may throw a code but have never had my SUV run like crap with a bad sensor, plus changing the O2 sensors is a pain in the ass! Check the vacuum lines!
TobyU
Ohio
The vacuum leaks also seem to be worse when temp is below 40.
Bruce Mitchell
Birnamwood, WI
With 235K you may have a cluster of vacuum leaks. I recently had heater core flushed, left the shop, got a mile down the road and saw steam coming from under the hood. Back to the shop, mech went to fix coolant leak - as he was working on that fitting (which disintegrated in front of both of us), the vacuum fitting behind it fell apart. He fixed that. Two days later the engine light comes on - codes for both O2 sensors bad. Was running fine, cleared codes, couple of days later engine light back on - codes for both banks too lean. And a misfire popped up from nowhere (and it didn't want to idle). Back to the shop - mech found and fixed bad PCV valve elbow fitting and another vacuum leak way down at the bottom back of the engine. Been running fine for a month now.
SO, start simple and work your way up. It's that Occam's Razor thing.
