tune ups?
Expedition907
Nome, Alaska
what tune up is needed after 100K miles? already did an oil change bout 1000K miles ago or less. figured id ask on here :deal: :hmm:
B
bedrck46
you can check you owners manual or go to owner.ford.com and download a copy of the maintenance sched that should have been in the expy when it was new
B
bedrck46
If you haven't done so already, get ready for the odyssey that is the spark plug replacement.
That's one of the nice things about the forum. The more input you get from others about potential "odyssey's" the better you can prepare yourself and hopefully avoid unnecessary problems. Yet even though you may be well informed sometimes things just seem to go wrong.
Best advice is to take your time.
Newport News, VA
I will check the book but I suggest oil change at maximum 5k mile intervals...
Newport News, VA
100k change includes plugs and everything else
FireRed5.4
Plugs and COP boots and springs, brake fluid flush, power steering fluid change, rear dif. grease, transfer case fluid, serp. belt & belt tension pulley, idler pulley, fuel filter, oil, trans filter, Thats about $300 - $350 in parts and you can do it all yourself in a day.
Expedition907
Expedition907
Nome, Alaska
might have to order these parts online...im in rural Alaska...
