Hey Lokiwolf, can you tell me more about the Hypertech you’re using , can you download custom tunes to it ? It’s almost 100 dollars cheaper than the SCT X4 at 4-Wheel parts.
Sure.
No custom Tunes. Only what it comes with. There are several adjustments you can make. Throttle Mapping and Shifting has several levels, and you can choose Performance Throttle, with Sport Shifting. You can also affect shift points. You set fuel, like 87 up to 93, then set the other settings.
I run 93, with Performance setting for Throttle and Shifting, and shift points at -100 RPM. I was having issues with it hitting redline when shifting under WOT and pulling fuel, so I did the -100. No issues since then.
I like that it can change TPMS setting and affect the Speedo. I was a BETA tester for the Expedition Tuning. At first the Shifting was not much better than Stock, but I worked with one of their Engineers and they have made significant improvements.
If you are looking for the best or most power it is not what I recommend. Go with Livernois, Unleashed, or 5-Star. It is good for the money though!
Also, look on Amazon, I have seen the price go below $300 a few times...
