Update on my Offroad Expedition on 35s
2012lI
Dubai
Hi guys, it has been a while since my last thread where I was gathering informations for diff swap.
The second pic is the modified expedition next to my identical 2wd expedition.
I am in the process of testing the shocks and might lift a bit more.
For now the truck feels great, very torquey and decent fuel economy and no rubbing with the 35s. The shocks are much better than the stock or bilstein that I had on my 2wd.
This is the update of the completed truck, here are the specs:
4.10 front differential, rear 4.10 ring and pinion both from first gen raptor
Baja kits upper control arms from f150
17" first gen raptor wheels with 315/70r17 Yokohama A/T tires
25mm wheel spacers
Profender 2.5 Shocks (equivalent to king or fox 2.5), f150 front shocks and altered silverado front shocks fitted in the back
Custom tubular front bumper with light bar/led lights
Rear bumper trimmed and skidplate
The back of the front fenders were trimmed and the running board was shortened to avoid rubbing
Aftermarket transmission cooler
2012lI
2012lI
Dubai
The raptor diffs swap was straighforward.
I directly swapped the front diff, for the rear I only replaced the pinion bearing then installed the ring and pinion to spec and that was it.
For now both are open diffs, might put a locker in the future.
Aces
Murrieta, CA
That’s a great looking expedition. What all did you have to modify to fit the rear coilovers? And how do they ride?
2012lI
2012lI
Dubai
Thank you! I got some inspo from your rig btw!
The top plate was replaced to fit the bolt pattern and also the lower bushing. The bushing was replaced and a sleeve has been put through.
Luckily the had all the spare parts for their shocks avl.
I will try to get better pictures of the rear coilovers
2012lI
2012lI
Dubai
Did you find a way to increase the rear wheel travel? It seems to be limited by the control arms
2012lI
2012lI
Dubai
They ride amazing, much much better than stock or the bilstein 4600 I had in the past.
They are on the firm side but not too firm, I really like them
Aces
Murrieta, CA
I have not. Albeit I haven’t looked into it. There is a crowd that have Raptor swapped their front suspension and I believe they are trying to find ways too.
Aces
Murrieta, CA
That’s awesome to hear. I need to get my Icons rebuilt but once I do that I’ll be happy with the ride again.
2012lI
2012lI
Dubai
JohnnyG
Fort Myers, FL
Your rig is BEAUTIFUL!
I have a 2024 Limited Expedition with the heavy-duty towing package and 2H, 4H, 4A, and 4L drive modes. It also has the Stealth package (not the performance package) with the CCD sport-tuned suspension. We bought it to tow our 2025 Polaris Xpedition.
We love almost everything about it—especially how well it rides on the highway. Our 4-month-old Expy already has just over 9,000 miles on it, most of which are highway. I've seen over 23 MPG on long trips.
We're spending the summer in western Colorado and finding ourselves on a lot of unpaved roads, some leading to trailheads in pretty rough shape. I’m starting to wonder if doing what you did would be worth it.
Mind if I ask a few questions?
- What kind of cost am I looking at to do what you did?
- Does it delete the CCD suspension?
- How does it ride on the highway afterward?
- Does it impact MPG?
Thanks,
JG
