water leak in rear driver side area
javeedmoe1
Houston
hey I'm new to this forum and this is actually my first day on this forum so here It goes. I have a 2000 Eddie Bauer expedition 5.4 liter and I recently started having a leak in the rear driver side area. I have to refill the truck with water every morning so the Truck doesn't overheat. it looks like the leak is coming from a line in the rear of the truck just wanted to see if anyone else has ever had this problem thanks any info helps
Mediamonkey11
Enumclaw, WA
The only thing back there coolant related in your rear air lines, just take a peek and see which one is leaking.
GaExpedition
us
My first thoughts are:
1 - the heater hose line that runs from behind the water pump, across the top of the block may be leaking at the back of the motor somewhere.
2 - Head gasket leaking or cracked head
3 - Intake manifold gasket at the rear of the engine leaking.
