Weathertech maintenance
Rick Anjel
Weston, Fl
What product do you use, if any to keep your Weathertech or aftermarket mats black and looking new?
sjwhiteley
Kentucky
If you are in an area where you really need them (snow, slush, dirt, etc) then there’s not much you can do to make them look new. After all, they are designed to protect the carpeting, so something has got to give.
Regular washing with soap and water: take them out and wash them the same time you wash the truck. I recommend not using 303 or armor all, as it tends to make them slippery, but does make them look ‘black’. YMMV.
the weathertech mats I had, after a few years, also developed wear spots.
Rick Anjel
Rick Anjel
Weston, Fl
Thanks for the tip, guess just water & soap should do the job. I was also thinking of using armor all, but as you mention it makes them slippery and dont want that.
Lou Hamilton
Maryland
I found SoftScrub and a coarse hand brush did the best when I had Weathertechs in my Pilot. But even then, they never kept their original bright black look. There were areas, especially where feet were always located, i.e., under gas pedal, where the coloring was worse than other areas.
I went the Husky route this time as I never really like that the Weathertechs never fully went to form along the edges. I always had a tons of sand and small stones under the mats. Did great for wet rain or snow, but really sucked for dirt.
I will be using the SoftScrub on the Husky's so hopefully, I will see a similar result.
Black
Kentucky
There are plenty of products that will bring WeatherTech (or any brand) liners and mats back to life even in the harshest of use.
The best I have found (even better than WeatherTech's own) is this by Chemical Guys.
https://www.amazon.com/Chemical-Guy...=2025&creative=165953&creativeASIN=B01C6AISUK
Get yourself a nice course bristled brush spray it on and let it soak awhile then scrub away. They look good as new, smell like grape, and are not slippery at all when dry!
Rick Anjel
Rick Anjel
Weston, Fl
Great! Will try it!
Flexpedition
midwest
Mop & Glo. A couple of drops on each mat, spread out with a damp terry cloth. The bottle should literally last for years.
sjwhiteley
Kentucky
duneslider
Utah
Try "Trim Shine". Once you scrub it the trim shine works great at making them look new. I'm not that picky anymore and once I wash them I just hit them with some window cleaner and it looks good enough for me.
RC Fan
Canada
I use Mineral oil on mine. It is cheap, and can be found in the digestive section in your local pharmacy.
I mix the oil with water and rub it in well. I usually do two coats.
Boose
2017 Platinum EL
NJ
I don't have Weathertech, but I do have the factory all weather rubber mats in both my Expedition & F150. I take them out and scrub them down with a stiff bristle brush rinse and blow them dry. so far, so good.
Apollo02exp
Diego
I suggest using Miguires or Mother's Back to Black. Works great on all non painted plastics, vinyl and rubber and even on black metal trim. Both products have UV protection and last for months against rain or washing. Apply just like wax, apply with a microfiber applicator and buff off a microfiber towel.
Wayne Decker
New York State
I put Husky mats on top of my WeatherTechs to protect them (and the WeatherTechs protect the carpet, which protects the floorboards. I'm thinking of adding generic rubber floor mats on top of the Huskies for a little better protection. Oh, and ArmorAll on the generics.
Artie
Georgia
Protection from what, xenomorph blood?!? That’s, like, 4 layers of protection lol
stricnine
Florida
I’m in the sunshine state so the FORD mats are perfect! Wash with brush and soap, blow dry them and back in and they look brand new for years! Their softer material doesn’t show wear like weathertech.
